6 years, 5 months ago.
Anyone successfully tested CAN communication on NUCLEO-F103RB board with mbed-os5?
I am trying to test CAN communication using two NUCLEO-F103RB boards and two SN65HVD230DR transceivers. Literally I have spent the past two weeks on this, I am not able to establish the connection and I am also not able to figure out the issue. My code is tested one, it is running perfectly on Nucleo F767ZI with DIY dual Can shield (2xMCP2551) and MbedOS5 bare-metal profile.
//#define BOARD1 1 // comment out this line when compiling for board #2
#if defined(TARGET_STM32F103C8T6)
#define LED_PIN PC_13
const int OFF = 1;
const int ON = 0;
#else
#define LED_PIN LED1
const int OFF = 0;
const int ON = 1;
#endif
#if defined(BOARD1)
const unsigned int RX_ID = 0x100;
const unsigned int TX_ID = 0x101;
#else
const unsigned int RX_ID = 0x101;
const unsigned int TX_ID = 0x100;
#endif
#include "CANMsg.h"
Serial pc(USBTX, USBRX);
CAN can(PB_8, PB_9); // CAN Rx pin name, CAN Tx pin name
CANMsg rxMsg;
CANMsg txMsg;
DigitalOut led(LED_PIN);
Timer timer;
uint8_t counter = 0;
void printMsg(CANMessage& msg)
pc.printf(" ID = 0x%.3x\r\n", msg.id);
pc.printf(" Type = %d\r\n", msg.type);
pc.printf(" Format = %d\r\n", msg.format);
pc.printf(" Length = %d\r\n", msg.len);
pc.printf(" Data =");
for (int i = 0; i < msg.len; i++)
pc.printf(" 0x%.2X", msg.data[i]);
pc.printf("\r\n");
int main(void)
pc.baud(9600); // set serial speed
#if defined(BOARD1)
led = ON; // turn the LED on
timer.start(); // start timer
pc.printf("CAN_Hello board #1\r\n");
#else
led = OFF; // turn LED off
pc.printf("CAN_Hello board #2\r\n");
#endif
can.frequency(1000000); // set CAN bit rate to 1Mbps
can.filter(RX_ID, 0xFFF, CANStandard, 0); // set filter #0 to accept only standard messages with ID == RX_ID
while (1) {
if (timer.read_ms() >= 2000) {
// check for timeout
timer.stop(); // stop timer
timer.reset(); // reset timer
counter++; // increment counter
txMsg.clear(); // clear Tx message storage
txMsg.id = TX_ID; // set ID
// append data (total data length must not exceed 8 bytes!)
txMsg << counter; // one byte
if (can.write(txMsg)) {
// transmit message
led = OFF; // turn the LED off
pc.printf("-------------------------------------\r\n");
pc.printf("CAN message sent\r\n");
printMsg(txMsg);
pc.printf(" counter = %d\r\n", counter);
else
pc.printf("Transmission error\r\n");
if (can.read(rxMsg)) {
pc.printf("CAN message received\r\n");
printMsg(rxMsg);
if (rxMsg.id == RX_ID) {
rxMsg >> counter;
timer.start(); // to transmit next message
Hello Dheeraj,
Yes, I did. It works fine when built with the online compiler using the latest Mbed OS 5.14.2 library (rev. 3a57ec7401).
- When building for board #1 make sure you have:
#define BOARD1 1 ...
and when building for board #2:
//#define BOARD1 1 ...
- Check your wiring. It should be as shown on this schematic.
- When the above does not help, to rule out faulty CAN transceivers you can try CAN bus without transceivers. But in that case you should reduce the CAN bus speed to 500 kbps :
... can.frequency(500000); ...
Hi Zoltan, I have commented out the first line while using the code for board 2 and wiring also seems right. I am not understanding the problem. I also tried by changing the transceivers but this one also did not work. Just my board 1 is able to send data for the first time and then board 2 is not able to receive data. This is the same issue that I am facing from the beginning.
posted by 02 Nov 2019- Have you tried CAN bus without transceivers?
- Make sure grounds are also connected to each other.
Hi Zoltan, My CAN code did not work even in loopback mode(i.e without transceivers). I am not understanding where the problem exactly is. Personally you have checked the code with NUCLEO-F103RB and also worked fine for others who were using LPC boards. Which mbed revision would work fine and can you suggest anything regarding this?
posted by 04 Dec 2019
