6 years, 5 months ago.
No targets folder under mbed-os in online compiler
/media/uploads/technovus/no_targets.jpg
I need to make some changes to the target, but there is no targets folder appearing under mbed-os in the online compiler. How can I access that folder using the online compiler?
I specifically want to adjust can_api.c to modify some of the settings. Thanks in advance!
Hi Dan,
If you would like to change code of Mbed OS and apply the change to your application, you should use offline Mbed CLI.
https://os.mbed.com/docs/mbed-os/v5.14/quick-start/offline-with-mbed-cli.html
Online compiler is not able to do that.
Regards, Desmond
