6 years, 5 months ago.
undefined reference to BLE::onEventsToProcess
Hello I'm new with mbed os,
I'm trying to compile an existing project from Eclipse but I have the followings errors;
..\testProject\Default/../BLEmanager.cpp:19: undefined reference to `BLE::onEventsToProcess(FunctionPointerWithContext<BLE::OnEventsToProcessCallbackContext*> const&)'
..\testProject\Default/../BLEmanager.cpp:24: undefined reference to `BLE::gap()'
./BLEmanager.o: In function `BLEmanager::start(bool, char const*)':
..\testProject\Default/../BLEmanager.cpp:37: undefined reference to `BLE::gap()'
..\testProject\Default/../BLEmanager.cpp:37: undefined reference to `Gap::onDisconnection(FunctionPointerWithContext<Gap::DisconnectionCallbackParams_t const*>)'
..\testProject\Default/../BLEmanager.cpp:38: undefined reference to `BLE::gap()'
..\testProject\Default/../BLEmanager.cpp:38: undefined reference to `Gap::onConnection(FunctionPointerWithContext<Gap::ConnectionCallbackParams_t const*>)'
..\testProject\Default/../BLEmanager.cpp:39: undefined reference to `BLE::accumulateAdvertisingPayload(GapAdvertisingData::DataType_t, unsigned char const*, unsigned char)'
..\testProject\Default/../BLEmanager.cpp:40: undefined reference to `BLE::gap()'
..\testProject\Default/../BLEmanager.cpp:44: undefined reference to `BLE::gattServer()'
./BLEmanager.o: In function `BLEmanager::disconnect()':
..\testProject\Default/../CrayoscopeBLEManager.h:26: undefined reference to `events::EventQueue::~EventQueue()'
./CrayoscopeBLEManager.o: In function `BLECharacteristic<unsigned char, 20u>::set(unsigned char const (&) [20], bool) const':
..\testProject\Default/../BLECharacteristic.h:44: undefined reference to `BLE::gattServer()'
./CrayoscopeBLEManager.o: In function `BLECharacteristic<unsigned char, 1u>::set(unsigned char const (&) [1], bool) const':
./main.o: In function `nrf_gpio_pin_port_decode':
..\mbed-os\targets\TARGET_NORDIC\TARGET_NRF5x\TARGET_SDK_14_2\drivers_nrf\hal/nrf_gpio.h:464: undefined reference to `assert_nrf_callback'
./main.o: In function `gpio_write':
It look like a linking error but I don't really understand the problem. The object file of my source are well generated. I already add all includes path in Eclipse Path and Symbol, so the compiler know the include path. I try to add the include path to the linker but that doesn't solved the problem. Here is the Eclipse generated Makefile:
# Automatically-generated file. Do not edit!
-include ../makefile.init
RM := del
# All of the sources participating in the build are defined here
-include sources.mk
-include subdir.mk
-include objects.mk
ifneq ($(MAKECMDGOALS),clean)
ifneq ($(strip $(CC_DEPS)),)
-include $(CC_DEPS)
endif
ifneq ($(strip $(C++_DEPS)),)
-include $(C++_DEPS)
endif
ifneq ($(strip $(C_UPPER_DEPS)),)
-include $(C_UPPER_DEPS)
endif
ifneq ($(strip $(CXX_DEPS)),)
-include $(CXX_DEPS)
endif
ifneq ($(strip $(ASM_DEPS)),)
-include $(ASM_DEPS)
endif
ifneq ($(strip $(S_UPPER_DEPS)),)
-include $(S_UPPER_DEPS)
endif
ifneq ($(strip $(C_DEPS)),)
-include $(C_DEPS)
endif
ifneq ($(strip $(CPP_DEPS)),)
-include $(CPP_DEPS)
endif
endif
-include ../makefile.defs
# Add inputs and outputs from these tool invocations to the build variables
# All Target
all: testProject
# Tool invocations
testProject: $(OBJS) $(USER_OBJS)
	@echo 'Building target: $@'
	@echo 'Invoking: GNU ARM Cross C++ Linker'
	arm-none-eabi-g++ -mcpu=cortex-m3 -mthumb -O0  -g3 -Xlinker --gc-sections -L"..\testProject\Default" -L"..\testProject" -Wl,-Map,"testProject.map" -o "testProject" $(OBJS) $(USER_OBJS) $(LIBS)
	@echo 'Finished building target: $@'
	@echo ' '
# Other Targets
clean:
	-$(RM) $(CC_DEPS)$(C++_DEPS)$(OBJS)$(C_UPPER_DEPS)$(CXX_DEPS)$(ASM_DEPS)$(S_UPPER_DEPS)$(C_DEPS)$(CPP_DEPS) testProject
	-@echo ' '
.PHONY: all clean dependents
.SECONDARY:
-include ../makefile.targets
Thank you for your help.
Regards Alexandre
Hello Alexandre,
Quote:
I'm trying to compile an existing project from Eclipse ...
  • How did you get the Eclipse project? (Was it exported from the online compiler?)
  • What is the target board you are compiling for?
  • To avoid troubles with "Eclipse + Mbed" I'd recommend you to give the Mbed Studio IDE a try. It's a great tool to work offline with Mbed.
posted by Zoltan Hudak 22 Oct 2019
Hello Zoltan,
I'm working from an existing student project already under Eclipse.
nRF52-PCA10040
I don't know why he starts with Eclipse, but it could still be interesting to understand the entire Mbed-os compilation process.
Regards Alexandre
posted by Alexandre Mendy 23 Oct 2019
Hello Alexandre,
Because to configure an Mbed project using Eclipse IDE could be quite troublesome (requires deeper knowledge of Mbed project structure) I'd suggest the following:
Thank you very much, I will try it today.
Regards Alexandre
