6 years, 5 months ago.
TM1637 is not working with L433 Nucleo module?
hello,
i am using 2 wire interface with L433 mbed mbed nucleo module.
but it is not working with that nucleo
Hi Arsadhusain,
I would suggest you first debug on hardware. Check the pin connected correctly, and the parameters for constructor TM1637_CATALEX CATALEX(p6, p7); //LPC1768 should match. If you have scope you can also check the waveform .
Regards, Desmond
