6 years, 5 months ago.
Thundersoft M4G9 - target not recognised.
I'm trying to compile a program for use on the Thundersoft M4G9 development, but the compiler reports:
Error: Target "TT_M4G9" is not recognized.
Anyone come across this - or know how to resolve this??
Hello Chris,
The online compiler and also the offline mbed-cli compiler work fine for me when building Mbed OS 5 project for the TT_M4G9 target. Make sure you are building a Mbed OS 5 project (it should contain a mbed-os library rather than a mbed one).
Hi there,
I do not have this board, so I only added that board into online compiler and I tried a standard blinky example with MbedOS5 (also a simplest version of that example with bare metal profile) with success result.
[Repository '/teams/mbed-os-examples/code/mbed-os-example-blinky/' not found]
I do not know what program you want to compile but be sure about your mbed library is up to date.
Best regards, Jan
Thanks Zoltan & Jan - I wasn't using the mbed-os project, I'm used to using the LPC1768 derivative dev kits.
posted by Chris C 23 Oct 2019
