6 years, 6 months ago.
The method of maiking two ADC and two DMA program
I could make one adc and one dma program, to study other quetions and answers. But I couldn't understand how to use two ADC and DMA , this question I worried. I want to perform two ADCs and DMAs simultaneously Please help me...
Below is my program
adc.cpp ______________________
  1. include "adc.h"
AnalogIn adc(A0); init GPIO stuff
/* HAL objects */ static ADC_HandleTypeDef hadc1; static DMA_HandleTypeDef hdma_adc1;
void adc::init() { ADC_init(); DMA_init();
memset(ADCVal, 0, sizeof(ADCVal)); }
void adc::read(uint16_t *data, uint32_t length) { ADC_ChannelConfTypeDef sConfig;
sConfig.Channel = ADC_CHANNEL_0; チャンネル0(ADC1_IN0:PA0)を使用 sConfig.Rank = 1; sConfig.SamplingTime = ADC_SAMPLETIME_3CYCLES; sConfig.Offset = 0;
HAL_ADC_ConfigChannel(&hadc1, &sConfig);
HAL_ADC_Start_DMA(&hadc1, (uint32_t *)data, length / 2); while (hdma_adc1.Instance->CR & DMA_SxCR_EN); spin HAL_ADC_Stop(&hadc1); }
void adc::ADC_init() { /* Peripheral clock enable */ ADC1_CLK_ENABLE();
/* Config ADC */ hadc1.Instance = (ADC_TypeDef *)ADC1; hadc1.Init.ClockPrescaler = ADC_CLOCKPRESCALER_PCLK_DIV4; ADCクロックプリスケーラ4 hadc1.Init.Resolution = ADC_RESOLUTION12b; 分解能12bit hadc1.Init.ScanConvMode = DISABLE; ENABLE:スキャンモード DISABLE:分割スキャンモード hadc1.Init.ContinuousConvMode = ENABLE; ENABLE:連続変換モード DISABLE:シングルモード hadc1.Init.DiscontinuousConvMode = DISABLE; 連続変換モード無効時、このパラメータは無効 hadc1.Init.NbrOfDiscConversion = 0; hadc1.Init.ExternalTrigConvEdge = ADC_EXTERNALTRIGCONVEDGE_NONE; 変換開始の外部トリガなし hadc1.Init.ExternalTrigConv = ADC_EXTERNALTRIGCONV_T1_CC1; hadc1.Init.DataAlign = ADC_DATAALIGN_RIGHT; 変換データを右詰め(RIGHT)か左詰め(LEFT)のどちらかを選択 hadc1.Init.NbrOfConversion = 1; AD変換する合計チャンネル数 hadc1.Init.DMAContinuousRequests = ENABLE; DMAコンテニューリクエスト hadc1.Init.EOCSelection = DISABLE;
/* 設定を反映 */ HAL_ADC_Init(&hadc1); }
void adc::DMA_init() { /* Peripheral clock enable */ DMA2_CLK_ENABLE();
/* Config DMA */ hdma_adc1.Instance = DMA2_Stream0; hdma_adc1.State = HAL_DMA_STATE_READY; HAL_DMA_DeInit(&hdma_adc1);
hdma_adc1.Init.Channel = DMA_CHANNEL_0; hdma_adc1.Init.Direction = DMA_PERIPH_TO_MEMORY; hdma_adc1.Init.PeriphInc = DMA_PINC_DISABLE; hdma_adc1.Init.MemInc = DMA_MINC_ENABLE; hdma_adc1.Init.PeriphDataAlignment = DMA_PDATAALIGN_HALFWORD; hdma_adc1.Init.MemDataAlignment = DMA_MDATAALIGN_HALFWORD; hdma_adc1.Init.Mode = DMA_NORMAL; hdma_adc1.Init.Priority = DMA_PRIORITY_HIGH; hdma_adc1.Init.FIFOMode = DMA_FIFOMODE_DISABLE; hdma_adc1.Init.FIFOThreshold = DMA_FIFO_THRESHOLD_HALFFULL; hdma_adc1.Init.MemBurst = DMA_MBURST_SINGLE; hdma_adc1.Init.PeriphBurst = DMA_PBURST_SINGLE;
/* 設定を反映 */ HAL_DMA_Init(&hdma_adc1);
/* 設定されたDMAハンドルをADC_DMAハンドルに関連付ける */ HAL_LINKDMA(&hadc1, DMA_Handle, hdma_adc1); } ___________________
adc.h ___________________
  1. ifndef _ADC_H
  2. define _ADC_H
  1. include <stdint.h>
  2. include "mbed.h"
  1. define ADC_TIMES 4000
class adc{ private: void ADC_init(); void DMA_init();
public: void init(); void read(uint16_t *data, uint32_t length);
uint16_t ADCVal[ADC_TIMES]; ADC result };
  1. endif __________________
Hello Fumiaki,
Try to click on the Edit button located in the top-right corner and then enclose your source code with <<code>> and <</code>> tags, each on separate line, like:
<<code>>
Your source
code.
<</code>>
After clicking on the Save Question button it will be displayed as formatted code.
posted by Zoltan Hudak 10 Oct 2019
