6 years, 3 months ago.
For loops don't work if more than 1 cycle
My for loop will not execute unless it is only one cycle. Code on either side will execute, the programme simply skips over the loop.
This is the full code, it runs perfectly fine:
full code
// Green LED
DigitalOut led1(LED1);
// Blue LED
DigitalOut led2(LED2);
// Red LED
DigitalOut led3(LED3);
void select_led(int l)
        if (l==1) {
                led1 = true;
                led2 = false;
                led3 = false;
        else if (l==2) {
                led1 = false;
                led2 = true;
                led3 = false;
        else if (l==3) {
                led1 = false;
                led2 = false;
                led3 = true;
    for(int i=2; i==2; i++) {
        select_led(i);
        wait(1);
If I change the for loop to this nothing happens:
bugged code
    for(int i=1; i==2; i++) {
        select_led(i);
        wait(1);
Hello Andre,
The condition in for loop is evaluated before each iteration.
In first case when
it evaluates to true
2==2 ? -> true
and the statements in the loop's body are executed.
In second case when
it evaluates to false
1==2 ? -> false
and the loop expires without executing the statements in the loop's body.
Try:
for(int i=1; i<=2; i++) {
    select_led(i);
    wait(1);
