6 years, 6 months ago.
Pin Connection for STM32F746G-DISCO and OV7670 camera module
Hi All, I'm trying to use this code ( https://os.mbed.com/users/buyukesmeli/code/BSP_DISCO_F746NG/ ) but i don't know how to connect camera to the board . Please any one has any idea how to connect to it .It will be very helpfull.
Thanks and Regards Aakash Patil
Hi Aakash,
Start by looking ST's digital camera interface which is available on Disco board: https://www.st.com/content/ccc/resource/technical/document/application_note/group0/c0/ef/15/38/d1/d6/49/88/DM00373474/files/DM00373474.pdf/jcr:content/translations/en.DM00373474.pdf This next links says that you should be able to connect camera module to the camera interface: https://www.openhacks.com/uploadsproductos/ov7670_cmos_camera_module_revc_ds.pdf
Regards, Pekka
Hi there,
I have no experience with a camera so this is only theoretical tips.
the BSP library is for peripherals of the board so the pins (check EOL comments ) are probably connected directly to the DCMI connector P1 on board's back side. That mean, that library already contain necessary pins inside the code. So when you have a variant of the camera with the flat flex cable for DCMI connector, you can try to write a test program with instructions whitch are inside the library.
Another option is an another library from mbed components or community.
GL and Br, Jan
