6 years, 5 months ago.
your example: "Viewing memory regions" does not work
Hi Jan,
I have tried using your example here, of "Viewing Memory regions". I get stuff printed to the screen but it is just gobbledegook.
Using an LPC1768
Any ideas why this is happening?
cheers,
Rory
Hi Rory,
Unfortunately Jan is not anomore answer these questions. I try it with Nucleo-F429 and compile with Online compiler. It works as it should. I copy paste Viewing memory regions over main.cpp in mbed-os-blinky-example. I tested 9600 and 115200 baudrates.
Have you test replace function call print_memory_info(); just prinf("Something\r\n"); ? Douple check baudrate in your terminal if you get gobbledegook out from basic printf.
Regards, Pekka
thanks for your answer Pekka. I will try these tests. has Jan left the company then?
posted by Rory Hand 08 Oct 2019
