6 years, 5 months ago.
nucleo l432kc + rfid RC522
hi,
I'm trying to use module RC522 with an nucleo l432kc.
I've used the library : RC522_LF, author teamFRA221:A
but when i compile the code i've the error : Error: Cannot open source input file "device.h": No such file or directory in "extras/mbed/platform.h", Line: 21, Col: 21
i've try to update the library but no change...
the code is the folowing :
//Test of cheap 13.56 Mhz RFID-RC522 module from eBay
//This code is based on Martin Olejar's MFRC522 library. Minimal changes
//Adapted for Nucleo STM32 F401RE. Should work on other Nucleos too
//Connect as follows:
//RFID pins -> Nucleo header CN5 (Arduino-compatible header)
//RFID IRQ=pin5 -> Not used. Leave open
//RFID MISO=pin4 -> Nucleo SPI_MISO=PA_6=D12
//RFID MOSI=pin3 -> Nucleo SPI_MOSI=PA_7=D11
//RFID SCK=pin2 -> Nucleo SPI_SCK =PA_5=D13
//RFID SDA=pin1 -> Nucleo SPI_CS =PB_6=D10
//RFID RST=pin7 -> Nucleo =PA_9=D8
//3.3V and Gnd to the respective pins
#include "MFRC522.h"
// Nucleo Pin for MFRC522 reset (pick another D pin if you need D8)
#define MF_RESET D8
DigitalOut LedGreen(LED1);
//Serial connection to PC for output
MFRC522 RfChip (SPI_MOSI, SPI_MISO, SPI_SCK, SPI_CS, MF_RESET);
int main(void) {
char uidcheck[ 100 ];
pc.printf("starting...\n");
// Init. RC522 Chip
RfChip.PCD_Init();
while (true) {
LedGreen = 1;
// Look for new cards
if ( ! RfChip.PICC_IsNewCardPresent())
wait_ms(500);
continue;
// Select one of the cards
if ( ! RfChip.PICC_ReadCardSerial())
wait_ms(500);
continue;
LedGreen = 0;
// Print Card UID
pc.printf("Card UID: ");
for (uint8_t i = 0; i < RfChip.uid.size; i++)
pc.printf(" %X02", RfChip.uid.uidByte[i]);
uidcheck[i] = RfChip.uid.uidByte[i];
pc.printf("\n\r");
// Print Card type
uint8_t piccType = RfChip.PICC_GetType(RfChip.uid.sak);
pc.printf("PICC Type: %s \n\r", RfChip.PICC_GetTypeName(piccType));
wait_ms(1000);
thanx for help
amos Jerome
