6 years, 5 months ago.
export uVision trouble
I used simple mbed-os-example-blinky. I tried exporting to uvison!! I used the following mbed command.
「mbed export -i uvision -m DISCO_L475VG_IOT01A」 but I could not export. See below....
[mbed] Working path "C:\work\mbed-os-example-blinky" (program)
DISCO_L475VG_IOT01A not supported by uvision5
[mbed] ERROR: "c:\python27\python.exe" returned error.
Code: 2
Path: "C:\work\mbed-os-example-blinky"
Command: "c:\python27\python.exe -u C:\work\mbed-os-example-blinky\mbed-os\tools\project.py -i uvision -m DISCO_L475VG_IOT01A profile debug source ."
Tip: You could retry the last command with "-v" flag for verbose output
I also tried the following two commands. 「mbed export -i uvision5 -m DISCO_L475VG_IOT01A」 ←Cannot export!!!! 「mbed export -i uvision6 -m DISCO_L475VG_IOT01A」 ←I was able to export!!!
Please tell us why the export is successful with 「mbed export -i uvision6 -m DISCO_L475VG_IOT01A」.
uvision5 is no longer supported, therefore use uvision6 please. There were changes not backward compatible with older version of uvision (how targets are being defined, etc).
