6 years, 6 months ago.
Using MAC filter with MeshInterface (Thread Mesh)
Hello guys,
i am working with the Mbed Thread Stack to build wireless sensor networks. Now I need the possibility to filter nodes (maybe based on their MAC address) so they can not communicate with each other, even if there are in range. I need this to set up a certain topology. I found the mac_filter_api.h which looks promising:
https://os.mbed.com/teams/onsemi/code/mbed-os/docs/tip/mac__filter__api_8h.html
To call the mac_filter_start ()-function I need an Interface_ID. Sadly my mesh-interface (https://os.mbed.com/docs/mbed-os/v5.13/mbed-os-api-doxy/class_mesh_interface.html) doesnt support the ".get_network_id()".
MeshInterface *mesh;
Starting MAC-filter with interface-id set to 0, 1, 2 .. dont cause any error but doesnt show any effect eigther. I'm using the standard "mesh-minimal-example" (https://os.mbed.com/teams/mbed-os-examples/code/mbed-os-example-mesh-minimal/), which is set up to use the Thread Stack.
Does anyone have another idea how to block nodes?
Best regards, Sebastian
Hello Sebastian,
You get Network interface ID when you create / start network. It is different than network ID. Interface ID is for that purpose that you have more than one mesh network in the same device - practically newer used. Because you have only one interface = Thread, it is most probably number 1. You can try that meanwhile I will try to find a correct way to find it out.
Regards, Pekka
Hello Pekka,
thanks for your infos. Nevertheless the filter isnt working. Not with Interface_ID 1, 0, 2 or 42. This is my code to set the filter up:
uint8_t MAC1[8] = {0xf4, 0xce, 0x36, 0x8a, 0xcc,0x4a, 0x0e, 0xef};
uint8_t MAC2[8] = {0xf4, 0xce, 0x36, 0x49, 0x94 ,0x8b, 0xdf, 0xb9};
int8_t IntID = 1;
printf("%d\n", mac_filter_start(IntID, MAC_FILTER_BLOCKED));
printf("%d\n", mac_filter_add_long(IntID, MAC1, MAC_FILTER_BLOCKED));
printf("%d\n", mac_filter_add_long(IntID, MAC2, MAC_FILTER_BLOCKED));
The "printf()" displays me a 0 to the CLI, so there should be no Errors. (>0: Error)
Regards, Sebastian
posted by 23 Sep 2019
