13 years, 3 months ago.
Problems with the mbed library
Hello
There is a problem with the mbed library. Apparently the library has been updated this morning. Since then I cannot compile when I start new projects. The compiler constantly shows errors:
/media/uploads/Frazzy/errors.jpg
This morning at (ca) 10 clock it was still working.
1. Project: mbed library update: 3 days, 4 hours ago 2. Project: mbed library update: 2 hours ago
Also the program with the old library from Friday don't compile anymore. And the new project with the updated library don't work too.
Publishing code can be handier, since it also includes the libraries you used. Anyway the problem seems to be the mbed library, you just need to go to an older version, todays update isnt the problem, but the one from a few days back. So revert to the version before that, and use the old MODSERIAL, and it works again. Looks like new version breaks fatfilesystem library.
At least I got it to compile that way again.
Edit: http://mbed.org/users/Sissors/code/Franziska That should work if you import it.
Ooooh, thank you... It works now. :*
posted by Franziska Gerlich 26 Nov 2012
Easiest solution: remove mbed library from your project, go to: http://mbed.org/users/mbed_official/code/mbed//builds/, import yesterdays build if the problem is just the build.
You can also publish your code and we can have a look at it. I assume FileHandle.h will also be used in LocalFileSystem, and the example project of that one still compiles fine. But then doesnt say that much.
(btw I do read german, just dont ask me to reply in it :P)
Maybe it's not the mbed library, but how can I solve the problem with the FAT file system, and then the SD card system. (because the SD File Systems needs the FAT) FAT and SD are somehow not compatible with the mbed library. No matter which version of the library I've tried.
Anyhow, here is my code:
#include "SDFileSystem.h"
#include "MODSERIAL.h"
MODSERIAL pc(USBTX, USBRX, 256);
Serial RS485(p26, p25);
DigitalOut DTR (p21);
// SDFileSystem sd(p11, p12, p13, p14, "sd");
LocalFileSystem local("local");
FILE *fp;
Timer timeout;
// Variablen
// Variablen zum Berechnen der Bytes und Speichern des Telegramms
int data               = 0;
int all_bytes          = 0;
int adress_byte        = 0;
int num_of_blocks      = 0;
int num_of_crc         = 0;
int counter            = 0;
// Variablen zum Ueberpruefen der Transitions
int trans_1            = 0;
int trans_2            = 0;
int trans_3            = 0;
int trans_4            = 0;
// Überwachungszeitstempel
int MonitoringTimestamp;
// Variable fuer den switch case
int state              = 0;
// Konstanten fuer den state-Wechsel des switch case
#define WAIT_FOR_ADRESS       0
#define WAIT_FOR_BLOCKCOUNT   1
#define WAIT_FOR_DATA         2
#define WAIT_FOR_ACKNOWLEDGE  3
// Konstanten fuer die Berechnung der Anzahl der zu empfangenen Bytes
#define DATA_BYTES            8
#define SEC_BYTES             4
// Funktionen
void transition1()
    trans_1 = 0;
    // Lese das erste Zeichen ein
    data = RS485.getc();
    // Uebergangsbedingung: Adressbyte empfangen
    if(data != 0) {
        pc.printf("%x ", data);
        trans_1 = 1;
    return;
void transition2()
    trans_2 = 0;
    // Lese die Blockanzahl als zweites Zeichen ein
    num_of_blocks = RS485.getc();
    // Uebergangsbedingung: Bytes empfangen
    if(num_of_blocks != 0) {
        pc.printf("%x ", num_of_blocks);
        trans_2 = 1;
    return;
void transition3()
    trans_3 = 0;
    // Uebergangsbedingung: Zaehler muss gleich 0 sein
    if(counter == 0) {
        trans_3 = 1;
    // Lese die vergangene Zeit in Millisekunden aus und speichere Sie in einer Variable
    MonitoringTimestamp = timeout.read_ms();
    // Wenn die vergangene Zeit 65 Millisekunden ueberschreitet, dann wechsel in WAIT_FOR_BLOCKCOUNT
    if(MonitoringTimestamp > 65) {
        pc.printf("(Nicht alle Bytes empfangen)\r\n\n");
        trans_3 = 2;
    return;
void transition4()
    trans_4 = 0;
    // Zeilenumbruch nach der Quittung "aa"
    if(data == 170) {
        pc.printf("\r\n\n");
        trans_4 = 1;
    } else {
        pc.printf("(Keine Quittung empfangen)\r\n\n");
        trans_4 = 2;
    return;
int action_state(int num_of_blocks)
    int all_bytes = 0;
    // Aktion: Berechne die Anzahl der zu emfangenden Bytes, Zaehler setzen
    // Anzahl der CRC-Bytes berechnen
    if(num_of_blocks % 3 == 0) {
        num_of_crc = num_of_blocks / 3;
    } else {
        num_of_crc = num_of_blocks / 3 + 1;
    // Anzahl aller Bytes berechnen
    all_bytes = (num_of_blocks * DATA_BYTES) + (num_of_crc * SEC_BYTES) - 1;
    return all_bytes; //Rückgabe der zu empfangenden Datenbytes
// Hauptfunktion
    struct tm t;
    // Starte den Timer
    timeout.start();
    // Entnehme die Sekunden der RTC des mbed's zum stellen der aktuellen Uhrzeit
    void set_time(time_t t);
           Achtung: Baudrate für die Uebertragung zum PC hochsetzen, sonst gehen
           auf diesem Weg Zeichen verloren. Auf der RS485 kommen die Daten schneller
           rein (65000) als sie in der Standardeinstellung für die PC-Verbindung
           (9600) abgegeben werden können. Ausserdem wird durch die Ausgabe als
           Hexwert gewissermassen aus einem empfangenen Wert zwei gesendete!
    // Setze die Baudrate des PCs auf 230400
    pc.baud (230400);
    // Setze die Baudrate von RS-485 auf 62500 Baud
    RS485.baud (62500);
    // Das Format von RS-485 ist 8 Bits, 1 Paritaetsbit und 1 Stopbit
    RS485.format(8,ParityForced1,1);
    // Um etwas empfangen zu koennen muss DTR immer gleich 0 sein
    DTR = 0;
    // Beziehe die SD-Karte als Datenlogger mit ein
    mkdir("/sd/mydir", 0777);
        // Lese die aktuelle Zeit von der RealTimeClock ab
        time_t seconds = time(NULL);
        // in Sekunden konvertieren
        time_t event_seconds = mktime(&t);
        // Bestimme ob es etwas vom RS485 zu lesen gibt
        if (RS485.readable()) {
            // Switch Case fuer die State Machine
            switch (state) {
                case WAIT_FOR_ADRESS :
                    // Pruefe die Uebergangsbedingung fuer den Wechsel nach WAIT_FOR_BLOCKCOUNT
                    transition1();
                    if (trans_1 == 1) {
                        // In den naechsten State wechseln
                        state = WAIT_FOR_BLOCKCOUNT;
                    break;
                case WAIT_FOR_BLOCKCOUNT :
                    // Pruefe die Uebergangsbedingung fuer den Wechsel nach WAIT_FOR_DATA
                    transition2();
                    if (trans_2 == 1) {
                        // Uebergangsaktion
                        counter = action_state(num_of_blocks);
                        // Setze den Timer auf Null
                        timeout.reset();
                        state = WAIT_FOR_DATA;
                    break;
                case WAIT_FOR_DATA :
                    // Lese alle restlichen Zeichen des Telegramms ein
                    // Nach jedem Byte wird der Zaehler verringert
                    counter--;
                    // Pruefe die Uebergangsbedingung fuer den Wechsel nach WAIT_FOR_ACKNOWLEDGE
                    transition3();
                    if (trans_3 == 1) {
                        // Wenn der Zähler auf 0 ist State wechseln. Quittung erwartet.
                        state = WAIT_FOR_ACKNOWLEDGE;
                    if(trans_3 == 2) {
                        // Wechsel in den State WAIT_FOR_BLOCKCOUNT wenn du nicht genug Bytes empfangen hast
                    // Schreibe die einzelnen Datenbytes als Hex-Zeichen im HyperTerminal heraus
                    timeout.reset();
                    break;
                case WAIT_FOR_ACKNOWLEDGE :
                    // Ueberprueft ob die Quittung empfangen wurde oder nicht
                    transition4();
                    // In den ersten State wechseln. Adressbyte erwartet.
                    if(trans_4 == 1) {
                        // Zeitpunkt holen bzw. den bereits geholten Wert umwandeln
                        struct tm *t;
                        t = localtime(&seconds);
                        // Oeffne die Datei telegram.txt
                        fp = fopen("/sd/mydir/telegram.txt", "a");
                        // Speichere den Zeitpunkt des empfangenen Telegramms in die Datei telegram.txt
                        fprintf(fp, "Zeit: %02d:%02d:%02d, Datum: %02d.%02d.%04d, Aktion: Telegramm empfangen\r\n",
                                t->tm_hour, t->tm_min, t->tm_sec,t->tm_mday,t->tm_mon+1,t->tm_year+1900);
                        // Datei wird geschlossen
                        fclose(fp);
                        // Wechsel in den State WAIT_FOR_ADRESS wenn du die Quittung erfolgreich empfangen hast
                        state = WAIT_FOR_ADRESS;
                    if(trans_4 == 2) {
                        // Wechsel in den State WAIT_FOR_BLOCKCOUNT wenn du keine Quittung empfangen hast, um ein neues Telegramm zu erhalten
                    break;
Okaay, problem: SD card file system. All the published libraries doesn't work -.-
See edit of previous one
posted by Erik - 26 Nov 2012
I don't think it is the problem with sdcard file system. The SDFileSystem from cookbook was working fine for me with mbed library revision 21 and 22. Yesterday I just updated mbed library to the latest and i get the same error.
Found out.........
FATFileSystem with SDCard.cpp , SDFileSystem and SDHCFileSystem worls with mbed library rev 39 or less.
Another solution:
Delete existing SDCard.cpp and .h file from project, delete FAT library, import this library:- http://mbed.org/users/mbed_official/code/SDFileSystem/
I did the same and it worked :)
Is your main file a .c file?
If so the compiler will compile as C not as C++. I've only ever seen the namespace error because of that.
Try renaming .c files to .cpp
