6 years, 6 months ago.  This question has been closed. Reason: Unclear question
variable does not get updated from serial input
hi,
I am writing a code for serial input from the PC to the KL25Z board and convert it to a float number and save to variable V1. it appears that the KL25Z successfully receives and convert the serial string into a floating point number, however it only print once and the value of V1 returns to initial value of 0,
May I know the error in the code causing this issue? thank you
here's my code
serial input
#include "millis.h"
Serial pc(USBTX, USBRX);
void serial_read(float *V0);
float V1 = 0;
unsigned short size_command;
long _time = 0;
    pc.baud(9600);
    millisStart();
        serial_read(&V1);
        if (millis() - _time > 1000) {
            _time = millis();
            pc.printf("%f\r\n",V1);
    if (pc.readable()) {
        size_command=pc.getc();
        char command[size_command];
        for (int i=0; i<size_command; i++)
            command[i]= pc.putc(pc.getc());
        sscanf(command, "%f", V0);
printf stop printing once I sent a serial string to the KL25Z, also the first digit is missing in the first trial. And it does not create a new line as well. /media/uploads/conrad2001/serial_V3S6pH3.png
thank you
