6 years, 7 months ago.
Dot-AT-Firmware Receive buffer clear
I was able to compile the "Dot-AT-Firmware" using the online compiler and loaded it to the xdot discovery kit. But while testing I noticed that the data received from the LORA gateway isn't cleared from the xdot receive buffer even after reading several times using the AT+RECV command. And also I got a message which I transmitted from the gateway a day before. So is there a way to clear the receive buffer for xdot such that I can get the latest message transmitted from the gateway.
