6 years, 7 months ago.
Are the library and examples working
Is this library tested and working, what hardware platform do you recommend its use with?
Apologies, I should add I just tried to compile the example for the K64f but there are a few compilation errors
posted by joe holdsworth 05 Sep 2019
Hi Joe,
I tried compiling the hello world example, and have M_PI not defined, if this is the same as your issue, you can try below two workaround.
1. Because M_PI is not in C standard, you might need to define it by yourself like #define M_PI 3.14159 2. Or you can change the compiler to use c99 or gnu11, that would need you use offline mbed-cli.
Regards, Desmond
thanks, there are quite a few compiler errors after solving that one, I'm stuck with the online compiler for now... thanks for taking the time to anser
posted by joe holdsworth 19 Sep 2019
