6 years, 8 months ago.
connection issues with i2C KL25Z as master and KL05Z as slave
Hi, updated: I noticed that the slave is holding the clock line down once it receives the write address command. Hope this helps solving the problem.
I tried to use I2C to connect KL25Z as master and KL05Z as slave, but it seems like the KL25Z master is not writing the correct data to the bus. It'd be great if anyone notice an error in the code. The i2c_slave1.receive() only returns 3, which is I2CSlave::WriteAddressed: no matter what the master sends to the slave I'd really appreciate to know what is going on in the I2C here's my updated code
KL25Z master
namespace master{
//I2C setup
I2C i2c(PTC9, PTC8);
Serial pc(USBTX, USBRX);
{ const int slave_addr = 0x0A ;
char cmd[1];
master::pc.baud(9600);
master::i2c.frequency(100000);
master::i2c.start();
cmd[0] = 0x01;
master::i2c.write(slave_addr,cmd,1,true);
master::i2c.stop();
cmd[0] = 0x02;
master::i2c.write(slave_addr,cmd,1);
master::i2c.stop();
wait(2);
cmd[0] = 0x03;
master::i2c.stop();
KL05Z slave
namespace slave1
DigitalOut green(LED_GREEN);
DigitalOut red(LED_RED);
DigitalOut blue(LED_BLUE);
I2CSlave i2c_slave1(PTB4, PTB3);
//I2C setup
{ const int slave_addr = 0x0A;
slave1::red = 1;
slave1::green = 1;
slave1::blue = 1;
i2c_slave1.frequency(100000); //Set the clock frequency
char buf[1];
char msg[1];
msg[0] = 0x00;
i2c_slave1.address(slave_addr);
while (1) {
int i = i2c_slave1.receive();
switch (i) {
case I2CSlave::ReadAddressed:
slave1::green = 0;
wait(1);
break;
case I2CSlave::WriteGeneral:
slave1::blue = 0;
wait(1);
break;
case I2CSlave::WriteAddressed:
slave1::red = 0;
wait(1);
break;
slave1::pc.printf("%i",i2c_slave1.receive());
for(int i = 0; i < 10; i++) buf[i] = 0; // Clear buffer
buf[0] = 0; // Clear buffer
i2c_slave1.stop();
i2c_slave1.receive(); only returns 3 no matter what the master sends
Hi Conrad,
Thanks for your questions and answer from you self (Good work!), I just link the post you gave and make sure anyone can find the answer to the same problem.
https://os.mbed.com/forum/mbed/topic/36122/?page=1#comment-63070
Regards, Desmond
