6 years, 2 months ago.
connection issues with i2C KL25Z as master and KL05Z as slave
I tried to use I2C to connect KL25Z as master and KL05Z as slave, but it seems like the KL25Z master is not writing the correct data to the bus. It'd be great if anyone notice an error in the code. When I print out the slave.receive() from the slave KL05Z, it always shows 0, so I guess it does not get any command from the master. Also I checked the oscilloscope, the waveform seems to be not sending the correct address and command, although I'm not sure.
Here's the code
KL25Z_master
//KL25Z_master
#include <I2C.h>
//define pin outs
Serial pc(USBTX, USBRX);
I2C i2c(I2C_SDA, I2C_SCL);
void i2C_master();
//i2C parameters
const int slave_addr = 0xA0 << 1;
    i2c.frequency(100000);
        i2C_master();
char cmd[1];
void i2C_master()
     cmd[0] = 0x01;
    i2c.write(slave_addr,cmd,1);
    // read and write takes the 8-bit version of the address.
    // set up configuration register (at 0x01)
    wait(0.5);
    i2c.read(slave_addr, cmd, 2);
    float tmp = (((cmd[0]<<8)|cmd[1]));
    printf("Temp = %s\n", cmd);
KL05Z slave
//KL05Z slave
//define pinouts
I2CSlave slave(PTB4, PTB3);
DigitalOut green(LED_GREEN);
DigitalOut blue(LED_BLUE);
DigitalOut red(LED_RED);
void i2C_slave();
//i2C parameters
const int addr = 0xA0 ;
    slave.frequency(100000);
    green = 1;
    blue = 1;
    red = 1;
    slave.address(addr);
        i2C_slave();
char buf[10];
char msg[] = {12345};
void i2C_slave()
       int i = slave.receive();
       switch (i) {
        case I2CSlave::ReadAddressed:
            //slave.write(msg, strlen(msg) + 1); // Includes null char
            green = 0;
            wait(0.5);
            break;
        case I2CSlave::WriteGeneral:
            blue = 0;
            wait(0.5);
            slave.read(buf, 10);
            printf("Read G: %s\n", buf);
            break;
        case I2CSlave::WriteAddressed:
            red = 0;
            wait(0.5);
            printf("Read A: %s\n", buf);
               break;
       pc.printf("%i",slave.receive());
       for(int i = 0; i < 10; i++) buf[i] = 0;    // Clear buffer
  1. include "mbed.h"/media/uploads/conrad2001/i2c.png
Hi Conrad,
Refer to user manual of KL05Z
http://cache.freescale.com/files/32bit/doc/ref_manual/KL05P48M48SF1RM.pdf
It uses 7-bit i2c address, that means you should set i2c_address to const int slave_addr = 0xA0;.
Regards, Desmond
thank you for the reply, I changed the address and the i2c_slave1.receive() only returns 3, which is I2CSlave::WriteAddressed: no matter what the master sends to the slave I'd really appreciate to know what is going on in the I2C here's my updated code
KL25Z master
namespace master{
//I2C setup
I2C i2c(PTC9, PTC8);
{   const int slave_addr = 0x0A ;
    char cmd[1];
    master::pc.baud(9600);
    master::i2c.frequency(100000);
        master::i2c.start();
        cmd[0] = 0x01;
        master::i2c.write(slave_addr,cmd,1,true);
        master::i2c.stop();
        cmd[0] = 0x02;
        master::i2c.write(slave_addr,cmd,1);
        master::i2c.stop();
        wait(2);
        cmd[0] = 0x03;
        master::i2c.stop();
KL05Z slave
namespace slave1
I2CSlave i2c_slave1(PTB4, PTB3);
//I2C setup
{   const int slave_addr = 0x0A;
    slave1::red = 1;
    slave1::green = 1;
    slave1::blue = 1;
    i2c_slave1.frequency(100000); //Set the clock frequency
    char buf[1];
    char msg[1];
    msg[0] = 0x00;
    i2c_slave1.address(slave_addr);
    while (1) {
        int i = i2c_slave1.receive();
        switch (i) {
                slave1::green = 0;
                wait(1);
                break;
                slave1::blue = 0;
                wait(1);
                break;
                slave1::red = 0;
                wait(1);
                break;
        slave1::pc.printf("%i",i2c_slave1.receive());
    buf[0] = 0;    // Clear buffer
    i2c_slave1.stop();
i2c_slave1.receive(); only returns 3 no matter what the master sends /media/uploads/conrad2001/3.png
posted by CONRAD CHAN 03 Sep 2019
