6 years, 7 months ago.
mbed TLS peer certificate verfication Fails
Hi Experts,
I am using mbed TLS client with Test certificates generated (using open SSL) and testing with local TLS server. In that case, peer certificate verification fails. Though I optionally turn off the peer certificate verification (MBEDTLS_SSL_VERIFY_OPTIONAL), in local setup how to test the same.
Hi lyf,
I apologize, but your use case is not clear to me.
How and where are you setting MBEDTLS_SSL_VERIFY_OPTIONAL in your client?
Does setting MBEDTLS_SSL_VERIFY_OPTIONAL have a successful ( though unsecure) connection?
What is the Mbed TLS version you are using?
Mbed Support
Ron
Assigned to Ron Eldor 6 years, 7 months ago.
