6 years, 8 months ago.
Why do I get "Use of deprecated scan API with up to date API" error
I am using the mBED 5.13.1 on both the peripheral and the central devices and I get the error below when I try to call stopAdvertisiing()
++ MbedOS Error Info ++
Error Status: 0x80180147 Code: 327 Module: 24
Error Message: Use of deprecated scan API with up to date API
Error Value: 0x0
Current Thread: main Id: 0x20003968 Entry: 0x636E7 StackSize: 0x1000 StackMem: 0x200077D8 SP: 0x20008180
For more info, visit: https://mbed.com/s/error?error=0x80180147
MbedOS Error Info
6 years, 7 months ago.
Hi John,
Referring to the doxy documentation here about disconnect(),
It says "Deprecated since addition of extended advertising support. Use disconnect(connection_handle_t, local_disconnection_reason_t) instead", so you need to call it with different parameters. You may need to add below code snippets.
void onConnectionComplete(const ble::ConnectionCompleteEvent &event) {
_connection_handle = event.getConnectionHandle();
ble_error_t error = _ble.gap().disconnect( _connection_handle,
ble::local_disconnection_reason_t::USER_TERMINATION );
ble::connection_handle_t _connection_handle;
Let me know if you need further help.
Thanks, Desmond
