6 years, 8 months ago.
mBed LPCXpresso55s69 blinky compile problem
I am using the online mBed to just evaluate the platform. I tried to simply compile the blinky example for the LPCXpresso55s69, but the compilation fails with:
Info: '../../../partition/region_defs.h' file not found in "tmp/QPAq2y", Line: 25, Col: 10 Error: L6636E: Pre-processor step failed for '/build/.link_script.sct' Info: Unable to download. Fix the reported errors...
this must be a probme with the online tool a sI have not suppllied any code or inputs to this process,
Any suggestions? Thanks
Hello Trevor,
My experience is that the compilation shall be repeated (sometimes it takes ten or even more attempts) until the error is gone. Maybe it happens because the online compiler is overloaded?
