6 years, 8 months ago.
How to write a char array to a file
Dear experts
I have an array of chars. I want to write this array to a log file on the flash storage. The code must work for any length of array. I already tried some stuff, but none of them worked for me. In best case, I want to form an array of chars or a string which can be written to the flash in one time.
Code
LocalFileSystem local("local");
#define ROOT_PATH "/local/"
const char log_file[] = ROOT_PATH "log.ini";
unsigned char myArray [] = {0, 50, 100, 150, 200};
int Main()
FILE *fp = fopen(log_file, "w");
fprintf(fp, "Start of log file\r\n");
fclose(fp);
//Some code I can't find
while(1)
Output:
Start of log file
array: 0 50 100 150 200
Thank you
Hello Jordy,
The following program works fine on my LPC1768 Mbed board when built with Mbed OS-5.13.2:
LocalFileSystem local("local"); // Create the local filesystem under the name "local"
FILE* fp = fopen("/local/log.ini", "w"); // Open "log.ini" text file on the local file system for writing
fprintf(fp, "Hello World!"); // Write "Hello World!" C-style string (terminated with 0) to the "log.ini" text file
fclose(fp); // Close the "log.ini" text file
- To make it work, after flashing disconnect and then reconnect the USB cable to the Mbed board. You should then see the
log.inifile on theMBEDvirtual disk and be able to open it in you favorite text editor. - Please notice that the "w" mode creates a text file for writing or truncates it to zero length. The character array to store shall be a C-style string (= character array terminated with 0 character). Because
myArrayin the example program above starts with 0 character it cannot be stored in such text file. - To store binary data use the "wb" mode as advised here. For example:
unsigned char myArray[] = { 0, 50, 100, 150, 200 };
FILE* fp = fopen("/local/log.ini", "wb"); // Open "log.ini" binary file on the local file system for writing
// Write myArray to the file.
for (size_t i = 0; i < sizeof(myArray) / sizeof(myArray[0]); i++)
fputc(myArray[i], fp); // Write an unsigned char (byte) from myArray to the file
fclose(fp); // Close the "log.ini" binary file
