6 years, 9 months ago.
FRDM_K66F Red LED Glows continuously
My New FRDM-K66F board was working and running smoothly my programs.
After flashing my code on the FRDM-K66F Board, the Red LED underneath the Reset Switch glows continuously. At every reset switch press, the RED LED glows continuously. It is not able to load my new code. I tried the Bootloader code flashing process as well. But still the result is the same.
After the code flashing the FRDM-K66F Folder shows FAIL.TXT file. FAIL.TXT shows following message: error: The interface firmware FAILED to reset/halt the target MCU type: target
