6 years, 9 months ago.
External power supply instead of micro USB port
Hi, how to provide power supply for PFM-M487 without micro-USB port? I've tried to supply power by connecting a voltage source(tried 512V) to VIN pin, but the LED on board even didn't light. I've tried to supply power by connecting a 5V voltage source to VCC, and the LED on board light, but the program didn't work as it did when connected to microUSB port.
This is really a good solution I have ever found at this best platform! voltage may be be in parallel or in series combination so we have variation voltage related to to external ports. I have ever used these methodology by getting help from https://bestassignmentwriter.co.uk/ and want to explore more n terms of technology.
Check the structure factor. On the off chance that you have Micro ATX you ought to have the option to purchase a power supply with no issue. In the event that you have a Dell or IBM with a little structure factor, you may be in a tight spot, on the grounds that the PSU structure factor is exclusive.https://www.nationalaccidentsupportline.co.uk/
posted by 27 Sep 2019
