6 years, 9 months ago.
Multiple SPI Port not working on Nucleo-F446RE
I am interfacing two Data Acquisition ICs with Nucleo-F446RE through two different SPI Port. Nucleo-F446RE is acting as the master for and is programmed to receive data from both of ICs. I have written the program with sufficient wait cycles so that program for two won't interfere with each other. The program is working for both of them in isolation i.e. when I comment the code for one device and give instruction for only one device the code is working perfectly but when I integrate the two, the clock for Nucleo is not coming correctly.
The code is attached below for your reference.
Affordable and flexible platform to ease prototyping using a STM32F446RET6 microcontroller.
