6 years, 8 months ago.
Make-GCC-ARM exported program build problem - unexpected EOF
Hi Arm,
my simple test program exported as Make-GCC-ARM fails to build locally under Visual Studio 2019. The problem is probably located in the following part of the MAKE file:
529> $(PROJECT).elf: $(OBJECTS) $(SYS_OBJECTS) $(PROJECT).link_script.ld 530> +@echo "$(filter %.o, $^)" > .link_options.txt 531> +@echo "link: $(notdir $@)" 532> @$(LD) $(LD_FLAGS) -T $(filter-out %.o, $^) $(LIBRARY_PATHS) --output $@ @.link_options.txt $(LIBRARIES) $(LD_SYS_LIBS)`
Received error:
/usr/bin/sh: -c: line 0: unexpected EOF while looking for matching `"' /usr/bin/sh: -c: line 1: syntax error: unexpected end of file C:/Test Projects/LCD_DEMO/Makefile:530: recipe for target 'LCD_demo.elf' failed
It seems there is something wrong with line 530. Please help.
