6 years, 9 months ago.  This question has been closed. Reason: Off Topic
Connecting UART Barcode Scanner with stm32f072rb nucleo board
Hello all,
I'm trying to figure out how to connect a UART barcode scanner with my stm32f072rb microcontroller. This is the barcode scanner that I am using: https://www.waveshare.com/wiki/Barcode_Scanner_Module
I'm trying to use the UART interface and I have been able to connect the cables correctly to the pins on the board(VCC to 5v, GND to GND, TXD to PA_10, RXD to PA_9). I have tried using example code on mbed's Serial API of passing data from an external UART device to the PC Serial monitor but I am not able to get anything to display to my serial monitor.
If anyone can help me out/give me some guidance where to look or send me a simple program that can output the barcode to the serial monitor via UART communication that would be greatly appreciated, thank you!
Connect wire from scanner TxD to RxD on board and scanner RxD to TxD on board and test again.
Best Regards.
Hi Vladimir,
Thank you for a quick response. I have tried disconnecting and reconnecting again and then running the program, but still nothing has worked. I don’t believe wiring is the issue here.
Update: I figured it out, for some reason my compiler wasn't working with the imported program, all I had to do was delete the program and reimport it into mbed and I was able to pass the data from my barcode scanner to my laptop's serial terminal.
posted by Shane F 28 Jun 2019
