6 years, 9 months ago.
Mbed filesystem mount fails
I am using the platform Nucleo-f207zg, and currently trying to use an SD card.
I am running the https://github.com/ARMmbed/mbed-os-example-sd-driver example and it works with one of my SD cards which I have been using for a long time with my codes and even this example.
The first time I tried using this SD card I had a bad time, and now that I am trying with new SD cards, again a lot of problems. I already formatted the new cards with Mac OS disk utility and with Windows using the guide on https://github.com/ARMmbed/mbed-os-example-sd-driver.
The programs always deliver the same error
--- Mbed OS filesystem example --- Mounting the filesystem... Fail :( No filesystem found, formatting... Fail :( error: Unknown error (-5005)
Does anyone have any suggestion?
Hello Jose,
- To format SD cards I use the SD Memory Card Formatter with the
Overwrite formatoption selected. - It was reported an issue regarding a wrong default SPI frequency (100000Hz) for the SD cad initialization. You can try to change it to a more suitable value (for example 350000Hz) by modifying the
mbed_app.jsonfile in the https://github.com/ARMmbed/mbed-os-example-sd-driver demo project as follows:
"config": {
"UART_RX": "D0",
"UART_TX": "D1",
"DIO_0": "D0",
"DIO_1": "D1",
"DIO_2": "D2",
"DIO_3": "D3",
"DIO_4": "D4",
"DIO_5": "D5",
"DIO_6": "D6",
"DIO_7": "D7",
"DIO_8": "D8",
"DIO_9": "D9",
"SPI_CS": "D10",
"SPI_MOSI": "D11",
"SPI_MISO": "D12",
"SPI_CLK": "D13",
"I2C_SDA": "D14",
"I2C_SCL": "D15",
"I2C_TEMP_ADDR":"0x90",
"I2C_EEPROM_ADDR":"0xA0",
"AIN_0": "A0",
"AIN_1": "A1",
"AIN_2": "A2",
"AIN_3": "A3",
"AIN_4": "A4",
"AIN_5": "A5",
"AOUT" : "A5",
"PWM_0": "D3",
"PWM_1": "D5",
"PWM_2": "D6",
"PWM_3": "D9",
"DEBUG_MSG": 0,
"DEVICE_SPI": 1,
"FSFAT_SDCARD_INSTALLED": 1
"target_overrides": {
"target.components_add": ["SD"],
"sd.INIT_FREQUENCY": 350000
Hello Zoltan,
I already did as suggested and now it just stays forever mounting the fileSystem. I do have two 16GB Class 10 SD cards working, and the one that is not working is a default 8GB Kingston SD Card. I don't know if this has something to do...
Thank you for your time answering! I wonder what is wrong?
posted by 28 Jun 2019
