6 years, 8 months ago.
Can connect more than two BLE_LED devices to BLE_LEDBlinker?
Hi there,
I've used Mbed online to connect one BLE_LEDBlinker device to one BLE_LED. It's run Ok.
I don't know whether we can use one BLE_LEDBlinker device to connect and work with more than two BLE_LED devices simultaneously?
Thanks.
Hi Sang,
Mbed OS is able to connect to multi peripherals simultaneously. To achieve this, you need to modify the example BLE_LEDBlinker.
First, you need to do another scan after the first connection complete.
Second, you need to add service/characteristic callback for each handle, handle is get by event.getConnectionHandle() in onConnectionComplete().
The example uses _is_connecting to prevent receiving more adv report, you also need to remove that.
Let me know if you have any questions.
Desmond
