6 years, 9 months ago.
I2C Not working on F411RE
Hello to everyone!
I am a novice so I apologize for posting probably trivial questions.
I tested I2C communication on stm F411RE using mbed compiler (on the cloud) and it does not work at all. I tried also port scan examples but the slave device is not detected. I verified the electric signals on the board, on all possible pins, but I could not find a clock (SCL).
I did the same test using CubeMX+TrueStudio and it works fine.
Any idea?
Thank you, Nicola
Some additional info: F411Re board is updated to the latest firmware The pins used for I2C communication are PB9 (SDA) and PB8 (SCL), explicitly set in both tests.
Affordable and flexible platform to ease prototyping using a STM32F401RET6 microcontroller.
Hi, can you place here your code (please use editing tips)?
posted by Jan Kamidra 03 Jun 2019
