6 years, 10 months ago.
How to end an event queue?
I would like to create an event queue, and then call a function ever 2 seconds for a total of 10 seconds (so likely 5 times), and then for the queue to stop executing the function. So a temporary event, but called every certain amount of time. I've tried this:
void handler(int c) {
    com.printf("Param: %d\r\n", c);
    EventQueue queue;
    int id = queue.call_every(2000,handler, 5);
    queue.dispatch();
    wait(10);
    queue.break_dispatch();
    queue.cancel(id);
    while (1) { }
But the function doesn't stop executing.
How can I stop the function from executing after some time x?
Hi there,
from my point of view your code not working because after you call the dispatch method without an argument, your code is blocked in indefinitely loop. https://os.mbed.com/docs/mbed-os/v5.12/mbed-os-api-doxy/classevents_1_1_event_queue.html#a397fcb417425ebaa28c20b9e90ef3ed5
Dispatch
void handler(int c) { printf("Param: %d\r\n", c);}
    printf("Start\n");
    EventQueue queue;
    queue.dispatch(10000);
    while (1) {myled = !myled; wait(0.5);}
I do not know if these ways are correct but function will stop/pause
Cancel
void handler(int c) { printf("Param: %d\r\n", c); }
    printf("Start\n");
    EventQueue queue;
    Thread t;
    t.start(callback(&queue, &EventQueue::dispatch_forever));
    wait(10);
    queue.cancel(id);
    while (1) {myled = !myled; wait(0.5); }
Pause
DigitalOut myled(LED1);
EventQueue queue;
Thread t;
InterruptIn mybutton(USER_BUTTON);
volatile bool ispressed = true;
void pressed(){ispressed = !ispressed;}
    if(ispressed == true){ printf("Param: %d\r\n", c); }
    printf("Start\n");
    mybutton.rise(callback(pressed));
and so on.
Best regards
J.
So I needed the queue to be bound to another thread to be able to cancel it. Thank you for your help, although it is odd how it doesn't work the same way in main().
posted by L B 03 Jun 2019
Instead of queue.call_every() use queue.call_in(), this schedules it just one time. Then reschedule it as many times as you want, and stop when needed. The function can even schedule itself if it has access to the EventQueue object.
Sorry, maybe I wasn't specific enough, but this doesn't help because at the point where I want to call the queue, the time it needs to run for is not known, which is why it is x rather than a known number.
