6 years, 10 months ago.
I Need to Help Interfacing of LTC2612 (DAC)
Hi
my project was using LTC2612 (DAC) chips
I read data sheet https://www.analog.com/media/en/technical-documentation/data-sheets/2602fa.pdf
How to interface LTC2612 chip using mbed os?
SPI? I2C?
Can I get some recommend this problem?
Regards
Hi Park,
I can give you only some tips
- I not check whole datasheet but I see nothing about I2C in the datasheet
- It looks like normal SPI but connected pins are only Chip Select, CLK, MOSI and MISO is not connected because the chip has only SDI = one way communication.
- I think you can use normal SPI without MISO and then follow instruction in datasheet.
Best regards
J.
