6 years, 10 months ago.
I2C PROGRAMMING ON ARM
I'M UNABLE TO USE I2C ON ARM CORTEX M3 PROCESSOR. WHAT AM I DOING WRONG? WHICH TEST COULD I PERFORM TO FIND THE PROBLEM?
THE ARM IS GD32F130C8 (MASTER DEVICE) AND I'M PROGRAMMING IT WITH KEIL (USING GD32F1x0 Firmware Library) THE SLAVE DEVICE IS MPU-6050 (ACCELEROMETER) I DEFINE THE VARIABLE WITH LOCAL ADDRESS AND MPU-6050 DEVICE:
#define I2C_ACCELEROMETER_ADDRESS 0xD0 //( 0x68 + one bit)
#define I2C_OWN_ADDRESS 0x72
THEN I INIT THE I2C PIN THIS WAY:
//Init I2C communication to accelerometer
// enable I2C0 clock
rcu_periph_clock_enable(RCU_I2C0);
// connect PB8 to I2C0_SCL
gpio_af_set(GPIOB, GPIO_AF_1, GPIO_PIN_8);
// connect PB9 to I2C0_SDA
gpio_af_set(GPIOB, GPIO_AF_1, GPIO_PIN_9);
gpio_mode_set(GPIOB, GPIO_MODE_AF, GPIO_PUPD_PULLUP,GPIO_PIN_8);
gpio_output_options_set(GPIOB, GPIO_OTYPE_OD, GPIO_OSPEED_50MHZ,GPIO_PIN_8);
gpio_mode_set(GPIOB, GPIO_MODE_AF, GPIO_PUPD_PULLUP,GPIO_PIN_9);
gpio_output_options_set(GPIOB, GPIO_OTYPE_OD, GPIO_OSPEED_50MHZ,GPIO_PIN_9);
THEN I INIT THE I2C THIS WAY:
void I2C_Accelerometer_init(void){
// configure I2C0 clock
i2c_clock_config(I2C0, 100000, I2C_DTCY_2);
// configure I2C0 address
i2c_mode_addr_config(I2C0, I2C_I2CMODE_ENABLE, I2C_ADDFORMAT_7BITS, I2C_OWN_ADDRESS);
// enable I2C0
i2c_enable(I2C0);
// enable acknowledge
i2c_ack_config(I2C0, I2C_ACK_ENABLE);
THEN PERIODICALLY (EACH SECOND) I TRY TO GET THE DATA FROM ACCELEROMETER. THERE IS NO ERROR BUT THE VARIABLE "Accelerometer_X_High" IS ALWAYS ZERO (THIS IS BASICALLY MY PROBLEM). THE FOLLOWING CODE IS EXECUTED EACH SECOND. AS YOU CAN SEE I SET POWER MANAGEMENT TO 0, THEN I REQUEST REGISTER WITH ACCELEROMETER DATA, THEN I TRY TO GET THE DATA FROM THE SLAVE DEVICE:
extern uint8_t Accelerometer_X_High;
//periodically called by timers in it.c
void GetAccelerometerData(void){
uint8_t bytesToReadIndex=0;
//WAKE UP ACCELEROMETER (6B 00)
// wait until I2C bus is idle
while(i2c_flag_get(I2C0, I2C_FLAG_I2CBSY));
// send a start condition to I2C bus
i2c_start_on_bus(I2C0);
// wait until SBSEND bit is set
while(!i2c_flag_get(I2C0, I2C_FLAG_SBSEND));
// send slave address to I2C bus
i2c_master_addressing(I2C0, I2C_ACCELEROMETER_ADDRESS, I2C_TRANSMITTER);
// wait until ADDSEND bit is set
while(!i2c_flag_get(I2C0, I2C_FLAG_ADDSEND));
// clear ADDSEND bit
i2c_flag_clear(I2C0, I2C_FLAG_ADDSEND);
// send a data byte
i2c_data_transmit(I2C0,0x6B); //PWR MANAGEMENT
// wait until the transmission data register is empty
while(!i2c_flag_get(I2C0, I2C_FLAG_TBE));
// send a data byte
i2c_data_transmit(I2C0,0x00); //WAKE UP
// send a stop condition to I2C bus
i2c_stop_on_bus(I2C0);
while(I2C_CTL0(I2C0)&0x0200);
//REQUEST ACELEROMETER DATA (3B )
// send a data byte
i2c_data_transmit(I2C0,0x3B); //ACCELEROMETER REGISTER
//now reopen the bus to receive the reply
i2c_master_addressing(I2C0, I2C_ACCELEROMETER_ADDRESS, I2C_RECEIVER);
// if we receive only one byte: reset ACKEN bit
i2c_ack_config(I2C0, I2C_ACK_DISABLE);
//clear ADDSEND bit
// if we receive only one byte: send stop condition
/* wait until the RBNE bit is set */
while(!i2c_flag_get(I2C0, I2C_FLAG_RBNE));
//read a data from I2C_DATA
Accelerometer_X_High = i2c_data_receive(I2C0);
// if we receive more bytes: send a stop condition to I2C bus
//i2c_stop_on_bus(I2C0);
acquiring signals with oscilloscope I get the following result:
this is a screenshot with entire signal:
On the signal there are also strange spikes:
Assigned to 6 years, 10 months ago.
Did you install external pullup resistors on both SDA and SCL lines? What value? Connecting a logic analyzer to the pins is the next logical step to confirm micro is outputing what you think it's outputing.
posted by Graham S. 19 May 20194,7k resistors. The doubt is on arm programming. I'm sure there is an error on the posted code but I couldn't find an example online
posted by gaucho bacca 20 May 2019I updated my question. please check oscilloscope acquisition and its decoding.
posted by gaucho bacca 27 May 2019It works. I read all the registers. There is no error on the firmware. The only problem is that the chip is not the one that I supposed it to be. I have to find the right part number of accelerometer and find the register to wake it up.
posted by gaucho bacca 29 May 2019
