6 years, 10 months ago.
Help needed: MODSERIAL software stops after a while, a buffer issue?
I'm using great MODSERIAL module in my software. Software runs fine but suddenly after a while it "stops". I see from debugger, that it does not hang but it wont send any commands to serial interface anymore. I don't know how to go forward. Let me explain my issue.
I have modem connected to my device that has LPC11U68.
I initialize the serial MODSERIAL
modem2(UART_TXD, UART_RXD, 128);
And I attach interrupts
	modem2.attach(&messageReceive, MODSERIAL::RxAutoDetect);
	modem2.attach(&rxCallback, MODSERIAL::RxIrq);
void messageReceive(MODSERIAL_IRQ_INFO *q) {
    MODSERIAL *sys = q->serial;
    char *found;
	sys->move(messageBufferIncoming, MESSAGE_BUFFER_SIZE);
    messageReceived = true;
    led_act = !led_act;
return;
void rxCallback(MODSERIAL_IRQ_INFO *q) {
	bool put_to;
	MODSERIAL *pc = q->serial;
	char c = pc->rxGetLastChar();
       // ... do things with the c
    return;
Then I send AT-commands to modem and fetch data from the internet.
Sofware loops this fetching so it is polling the website content.
I read the response.
After every command I try to empty the serial buffer calling getc.
	while(modem2.readable()) {
		c =  modem2.getc();
After some time something strange happens. Software is not hanging up but no led_act flashing, so I assume no command are sent to the modem. MODSERIAL's buffer[RxIrq|TxIrw] are both full. If i initialize MODSERIAL with larger buffer, same thing happens but it takes more time, that's why I initialize it 128B buffer.
What should I try next? Thank you!
