6 years, 11 months ago.
FRDM-K64F using SD card and RF/WIFI expansion board, spi conflict?
I am trying to use both SD card and RF/WIFI module but this doesn't seem to be possible because of both use the same SPI. Is there a workaround?
Hello Uwe,
You can have mutliple SPI devices (slaves) connected to the same SPI bus. The master (FRMD-K64F in this case) selects the actual device (slave) by bringing the CS (chip select) line low:
  • PTE4 when communicating with the SD card
  • PTD4 when communicating with the RF/WIFI
(Make sure that only one CS line is low at a time.)
