6 years, 12 months ago.
NUCLEO-F767ZI Ethernet Interface does not appear to work on 10Mbit network
All MBED OS 5 Network code appears to work with my 100Mbit network, but when plugged into a 10Mbit hub, I only get a blinking orange LED, but the LED on the left (green on 100 Mbit) is off.
I also notice that I do not get an ARP message on 10Mbit like I do on 100 Mbit. Is the interface supposed to to auto-negotiate speed and duplex (that is what the code says it is doing)
My interface is set with a static address:
... eth.set_dhcp(false); eth.set_network(address.io_addr, address.io_mask, address.gateway); ... and
EthHandle.Init.AutoNegotiation = ETH_AUTONEGOTIATION_ENABLE; EthHandle.Init.Speed = ETH_SPEED_100M; EthHandle.Init.DuplexMode = ETH_MODE_FULLDUPLEX;
I did try to modify the speed and duplex setting, no good!
Am I missing something?
Also note that the ST sample code that acts as a simple web server works at any speed... Just the MBED code does no work at 10 Mbit.
Thanks
Floyd
So no one has tried 10Mbit on this class of processor? Or am I the only one that it does not work for (MBED code only)...?
posted by Floyd Brown 02 Dec 2019
