6 years, 11 months ago.
Saving string from (RX,TX) to an array only when you press enter
Hello! I need help to store a string data type coming from a Bluetooth serial module (HC-05) (RX, TX) in an array. I have tried the following code, but I need the data to be stored in an array only when the enter key of the computer is pressed, thanks
serialtoarray
Serial pc(USBTX, USBRX);
Serial device(PA_9, PA_10);
volatile char command[8];
device.scanf("%7s", command);
pc.printf("%s\r\n", command);
