7 years ago.
Nucleo_L152RE SD Card problem
Hi Eweryone.
i have problem with connecting the SDHC card to the NUCLEO L152RE, gives the following message on uart while starting:
- Mbed OS filesystem example -Mounting the filesystem... Fail :(No filesystem found, formatting... Fail :(++ MbedOS Error Info ++Error Status: 0x80FF0100 Code: 256 Module: 255Error Message: Fatal Run-time errorLocation: 0x800F5A5Error Value: 0x0Current Thread: main Id: 0x20002348 Entry: 0x800FD11 StackSize: 0x1000 StackMem: 0x20001348 SP: 0x200022B8 For more info, visit: https://armmbed.github.io/mbedos-error/?error=0x80FF0100 MbedOS Error Info error: Unknown error (-5005)
1.my mbed_app.json is: { "target_overrides": { "*": { "platform.stack-stats-enabled": true, "platform.heap-stats-enabled": true, "platform.cpu-stats-enabled": true, "platform.thread-stats-enabled": true, "platform.sys-stats-enabled": true }, "NUCLEO_L152RE": { "target.components_add": ["SD"] } } }
2.my code in online compilator and latest mbed-os higher 5.10, i think 5.11:
/* mbed Microcontroller Library
 * Copyright (c) 2006-2013 ARM Limited
 * Licensed under the Apache License, Version 2.0 (the "License");
 * you may not use this file except in compliance with the License.
 * You may obtain a copy of the License at
 *     http://www.apache.org/licenses/LICENSE-2.0
 * Unless required by applicable law or agreed to in writing, software
 * distributed under the License is distributed on an "AS IS" BASIS,
 * WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
 * See the License for the specific language governing permissions and
 * limitations under the License.
#include <stdio.h>
#include <errno.h>
// Block devices
//#include "SPIFBlockDevice.h"
//#include "DataFlashBlockDevice.h"
#include "SDBlockDevice.h"
#include "HeapBlockDevice.h"
// File systems
#include "LittleFileSystem.h"
#include "FATFileSystem.h"
// Physical block device, can be any device that supports the BlockDevice API
SDBlockDevice  bd(D4,D5,D3,D7);
// File system declaration
LittleFileSystem fs("fs");
// Set up the button to trigger an erase
InterruptIn irq(USER_BUTTON);
void erase() {
    printf("Initializing the block device... ");
    fflush(stdout);
    int err = bd.init();
    printf("%s\n", (err ? "Fail :(" : "OK"));
    if (err) {
        error("error: %s (%d)\n", strerror(-err), err);
    printf("Erasing the block device... ");
    fflush(stdout);
    err = bd.erase(0, bd.size());
    if (err) {
    printf("Deinitializing the block device... ");
    fflush(stdout);
    err = bd.deinit();
    if (err) {
// Entry point for the example
    printf("--- Mbed OS filesystem example ---\n");
    // Setup the erase event on button press, use the event queue
    // to avoid running in interrupt context
    irq.fall(mbed_event_queue()->event(erase));
    // Try to mount the filesystem
    printf("Mounting the filesystem... ");
    fflush(stdout);
    int err = fs.mount(&bd);
    if (err) {
        // Reformat if we can't mount the filesystem
        // this should only happen on the first boot
        printf("No filesystem found, formatting... ");
        fflush(stdout);
        err = fs.reformat(&bd);
        if (err) {
    // Open the numbers file
    printf("Opening \"/fs/numbers.txt\"... ");
    fflush(stdout);
    FILE *f = fopen("/fs/numbers.txt", "r+");
    printf("%s\n", (!f ? "Fail :(" : "OK"));
    if (!f) {
        // Create the numbers file if it doesn't exist
        printf("No file found, creating a new file... ");
        fflush(stdout);
        f = fopen("/fs/numbers.txt", "w+");
        if (!f) {
            error("error: %s (%d)\n", strerror(errno), -errno);
        for (int i = 0; i < 10; i++) {
            printf("\rWriting numbers (%d/%d)... ", i, 10);
            fflush(stdout);
            err = fprintf(f, "    %d\n", i);
            if (err < 0) {
                printf("Fail :(\n");
        printf("\rWriting numbers (%d/%d)... OK\n", 10, 10);
        printf("Seeking file... ");
        fflush(stdout);
        err = fseek(f, 0, SEEK_SET);
        printf("%s\n", (err < 0 ? "Fail :(" : "OK"));
        if (err < 0) {
    // Go through and increment the numbers
        printf("\rIncrementing numbers (%d/%d)... ", i, 10);
        fflush(stdout);
        // Get current stream position
        long pos = ftell(f);
        // Parse out the number and increment
        int32_t number;
        fscanf(f, "%d", &number);
        number += 1;
        // Seek to beginning of number
        fseek(f, pos, SEEK_SET);
        // Store number
        fprintf(f, "    %d\n", number);
        // Flush between write and read on same file
        fflush(f);
    printf("\rIncrementing numbers (%d/%d)... OK\n", 10, 10);
    // Close the file which also flushes any cached writes
    printf("Closing \"/fs/numbers.txt\"... ");
    fflush(stdout);
    err = fclose(f);
    if (err < 0) {
    // Display the root directory
    printf("Opening the root directory... ");
    fflush(stdout);
    DIR *d = opendir("/fs/");
    printf("%s\n", (!d ? "Fail :(" : "OK"));
    if (!d) {
    printf("root directory:\n");
    while (true) {
        struct dirent *e = readdir(d);
        if (!e) {
            break;
        printf("    %s\n", e->d_name);
    printf("Closing the root directory... ");
    fflush(stdout);
    err = closedir(d);
    if (err < 0) {
    // Display the numbers file
    fflush(stdout);
    f = fopen("/fs/numbers.txt", "r");
    if (!f) {
    printf("numbers:\n");
    while (!feof(f)) {
        int c = fgetc(f);
        printf("%c", c);
    printf("\rClosing \"/fs/numbers.txt\"... ");
    fflush(stdout);
    err = fclose(f);
    if (err < 0) {
    // Tidy up
    printf("Unmounting... ");
    fflush(stdout);
    err = fs.unmount();
    if (err < 0) {
    printf("Mbed OS filesystem example done!\n");
please help me connect sdcard to my nucleo!!!
