13 years, 3 months ago.
Modserial doesn't work?
Hello
I know I've asked a lot questions about using "serial.h" etc. . However, there are more problems. Is it right that the serial (or modserial) libraries are outdated. I have tried all modserial libraries that were available, but it didn't work.
Maybe someone has an idea how I could manage that?
My code:
#include "MODSERIAL.h"
// Make TX buffer 1024bytes and RX buffer use 512bytes.
MODSERIAL pc(USBTX, USBRX, 256); // tx, rx
Serial RS485(p26, p25);
DigitalOut DTR (p21);
// Hauptprogramm
// Setze die Baudrate des PCs auf 230400
pc.baud (230400);
// Setze die Baudrate von RS-485 auf 62500 Baud
RS485.baud (62500);
// Das Format von RS-485 ist 8 Bits, 1 Paritaetsbit und 1 Stopbit
RS485.format(8,ParityForced1,1);
// Um etwas empfangen zu koennen muss DTR immer gleich 0 sein
DTR = 0;
// Increase the TX buffer from the default 256bytes to 1024bytes.
if (pc.txBufferSetSize(1024) != MODSERIAL::Ok) {
error("Failed to allocate memory for new buffer");
if (RS485.readable()) {
pc.printf("%x ", RS485.getc());
// RS485.attach(&rxCallback, MODSERIAL::RxIrq);
The Libraries i've tried:
The error messages:
See the MODSERIAL cookbook page: http://mbed.org/cookbook/MODSERIAL
New mbed library broke it, and first version of new mbed library had broken serial interrupts, breaking modserial even further. Since apparently Andy hasnt gotten to uploading a working version yet I uploaded mine: http://mbed.org/users/Sissors/code/MODSERIAL/
I think it should work, but if you find a small bug tell me and i have a look if i can fix it easily.
If you don't understand german, please tell me, then I try in english later. :D
Ich sehe du kommst aus den Niederlanden, kannst du Deutsch?
Denn es gibt etwas größere Probleme die ich schlecht in Englisch beschreiben kann.
Also die mbed-library wurde anscheinend geupdated und seitdem funktioniert bei keinem neuen Projekt die Kompilierung.
Eines der Errors z.B.: "identifier "namespace" is undefined" in file "mbed.bldFileHandle.h", Line: 35, Col: 1
und es gibt bestimmt 30 Errors alle in filehandle.h aus der mbed-library. Ich kann keine Projekte mehr kompilieren, da irgendwas an der library verändert wurde, heute morgen ging dieses Projekt noch.
Bitte helf mir :D
posted by 26 Nov 2012
