6 years, 10 months ago.
I2C slave & I2C Master
Hello Is it possible to reconfigure an I2C module and switch between I2C slave and I2C master during runtime using the Mbed framework?
Example:--
1). Configure a Mbed board as an I2C slave. 2). Then at some point reconfigure the same I2C port as an I2C master (after a specific slave i2c command is received or a push switch is pressed).
Thanks
Hi, probably yes...
something...
I2C *master;
I2CSlave *slave;
if (/*something*/) {
master = new I2C(PB_3, PB_10);
slave = new I2CSlave(PB_9, PB_8);
}else{
master = new I2C(PB_9, PB_8);
slave = new I2CSlave(PB_3, PB_10);
delete slave;
delete master;
