7 years ago.
Include .a file during compilation
Hi there,
I have a library that's been compiled into a .a file that I need to include in a program. The library has been specifically compiled for a Cortex M0+ and I am using an STM32 L073RZ which uses this processor. Simply put, my question is: How do I use the mbed-cli tools to include this file when compiling?
Thanks, Adam
7 years ago.
Hello Adam,
You can find an example in Mbed OS documantation at Compiling static libraries, 2. Compile multiple applications or tests against the static library.
- Copy the header file associated with the library to your project's folder and
#includeit into themain.cppfile - Open a command prompt in your project's folder.
- Issue the following command:
mbed compile -t GCC_ARM -m NUCLEO_L073RZ --source=. --source=[relative path from your project folder to the folder that contains the .a file]
