7 years, 1 month ago.
Setting a configuration variable to compiler or mbed system
Hello guys,
I'm trying overwrite a variable that is set in the file "mbed-os/targets/targets.json", but I don't having success. The default of the variable that I want set is "default_lib": "small", and I'm needing set to "default_lib": "std", the only way that work for me is set directilly in the file "mbed-os/targets/targets.json", but I think that isn't the rigth way. Is there another way of editing just a file in the application part of the project and don't a file of the framework? I tried to set it in the mbed_app.json, but didn't work (or I don't set it).
Thanks,
7 years ago.
Hi Willian,
You are correct - the proper way to modify the build configuration is through the local project file (at your project root) called mbed_app.json. You can read about the configuration system here:
The syntax for the file needs to be exact. In your instance, if you want to override the small library with "std" you can use this for your mbed_app.json. In this example I've used a LPC11U24 target:
"target_overrides": {
"LPC11U24": {
"target.default_lib": "std"
If you think this isn't working, could you post your mbed_app.json with the final few lines of the build output which shows the libraries being included as shown here:
[DEBUG] LPC Patch: os2_test.bin | Module | .text | .data | .bss | |-------------------|---------------|-------------|----------| | BUILD\LPC11U24 | 68(+0) | 4(+0) | 24(+0) | | [fill] | 91(+4) | 0(+0) | 6(+3) | | [lib]\c.a | 18147(+18147) | 2472(+2472) | 89(+89) | | [lib]\c_nano.a | 0(-3511) | 0(-100) | 0(-12) | | [lib]\gcc.a | 9228(+8184) | 0(+0) | 0(+0) | | [lib]\mbed.a | 1130(+8) | 4(+0) | 13(+0) | | [lib]\misc | 244(+0) | 8(+0) | 28(+0) | | mbed\97feb9bacc10 | 3258(+0) | 8(+0) | 280(+0) | | Subtotals | 32166(+22832) | 2496(+2372) | 440(+80) |
Ralph, Team Mbed
