6 years, 11 months ago.
I'm using a different sensor, how can I modify this code to make it work?
I'm using the sonar found in this link: https://www.robotshop.com/ca/en/weatherproof-ultrasonic-sensor-separate-probe.html Does anyone know what the differences might be between sensors that could cause this code not to work for another? The trigger pin initialization is the same at 10us. Thanks in advance
