6 years, 11 months ago.
DISCO_L475VG_IOT01A AnalogIn reads positive number when grounded
I am having a very strange problem with the DISCO_L475VG_IOT01A board...
The code below is practically copied from the mbed-os AnalogIn example. However, the values I read are wacky. When I ground the A1 pin, I read roughly 31831 (varies +/- 20 occasionally). When I connect it to 3.3V (VDD), I read roughly 64367 (also varies, which is actually close to what it should be). Why on earth is a grounded A1 pin reading roughly half of the range of a 16 bit number? It seems the whole range is shifted by about 2^15 = 32768.
// Initialize a pins to perform analog input and digital output fucntions
AnalogIn ain(A1);
int main(void)
    while (1) {
        uint16_t val = ain.read_u16();
        printf("%u \n\r", val);
        wait(0.1f);
