7 years ago.
How to check a pin supports required capture functionality?
I'm writing a class that uses the capture functionality of the timer block. Different devices have certain fixed location pins that support capture functionality. If I want to allow the user of the class to select which pin they want to use, how can I check that they've selected a pin that actually has the capture functionality?
Thanks.
7 years ago.
Hello, Shareef
There are probably many ways how to do it. You can for example let the compiler check/enforce it by declaring an enum type and class as follows:
MyClass.h
#define "mbed.h"
typedef enum {
#if defined(TARGET_LPC1768)
    capturePin1 = p9,
    capturePin2 = p10,
#elif defined(TARGET_STM)
    capturePin1 = PA_3,
    capturePin2 = PA_4,
    capturePin3 = PB_10,
    capturePin4 = PC_4,
#endif
} CapturePin;
class MyClass : public InterruptIn
public:
    MyClass(CapturePin pin) : InterruptIn((PinName)pin)
The user will be then forced to use only the designed pins:
main.cpp
#include "MyClass.h"
//MyClass myClass(p9);           // reports compile time error
MyClass myClass(capturePin3);  // compiles fine for STM boards but reports compile time error for LCP1768
