7 years, 1 month ago.
How do I stop serial dropping characters on Nucleo F411RE or F401RE when tickless is enabled.
I can not get all characters via serial reliably from Nucleo F411RE or F401RE when I have tickless enabled. I am talking to a cellular modem at 115200 baud. This seems to be a similar or the same problem listed in https://github.com/ARMmbed/mbed-os/issues/8714 except for a different board. This issue has been closed and looks like it has been merged but I am loosing characters with the F411RE.
As soon I as I remove
"target.macros_add": ["MBED_TICKLESS","DEVICE_LPTICKER"],
RawSerial Modem(PA_9, PA_10,115200);
DigitalIn mybutton(USER_BUTTON);
DigitalOut led2(PA_5,0);
LowPowerTimer t;
char c;
bool found = false;
char respBuffer[500]="";
int bsize = sizeof(respBuffer);
Modem.set_flow_control(Serial::RTS,PA_12,PA_11);
printf("Ready...\n");
if(mybutton == 0) {
led2=1;
wait(1);
led2=0;
printf("Sending ATI1\n");
Modem.puts("ATI1\r");
t.start();
char test[10] = "OK\r";
int eLen = strlen(test);
int i=0;
while(t.read_ms() < 10000){
while (Modem.readable()) {
c = Modem.getc();
if(i<bsize) {
respBuffer[i] = c;
respBuffer[i+1]=0;
i++;
if(i>eLen){
int match = memcmp(test,&respBuffer[(i-eLen)],eLen);
if(match == 0 ){
found=true;
break;
t.stop();
printf("Found:%d\nOUTPUT:\n$$%s$$\nmilliSec: %d\n",found,respBuffer,t.read_ms());
ThisThread::sleep_for(1000);
from my mbed_app.json file, no characters are lost.
Output with tickless
Sending ATI1 Found:1 OUTPUT: $$ ATI1 CinterionELS31-V REVISION 4.3.0c A-REVISION 4.3.3.0-36343 L-REVISION 3.7.6 OK $$ milliSec: 218 Sending ATI1 Found:1 OUTPUT: $$ ATI1 Cinterion ELS31-V VISION 4.3.0c A-REVION 4.3.3.0-36343 L-REVISION 3.6 OK $$ milliSec: 327 Sending ATI1 Found:1 OUTPUT: $$ ATI1 Cinterio ELS31-V REVISION 4.3.0c A-RESION 4.3.3.0-36343 L-REVISION 3.6 OK $$ milliSec: 436
Output without tickless
Sending ATI1 Found:1 OUTPUT: $$ ATI1 Cinterion ELS31-V REVISION 4.3.3.0c A-REVISION 4.3.3.0-36343 L-REVISION 3.7.6 OK $$ milliSec: 314 Sending ATI1 Found:1 OUTPUT: $$ ATI1 Cinterion ELS31-V REVISION 4.3.3.0c A-REVISION 4.3.3.0-36343 L-REVISION 3.7.6 OK $$ milliSec: 423 Sending ATI1 Found:1 OUTPUT: $$ ATI1 Cinterion ELS31-V REVISION 4.3.3.0c A-REVISION 4.3.3.0-36343 L-REVISION 3.7.6 OK $$ milliSec: 532
Any ideas on what I should try? Is this bug not fixed or is it just fixed for a specific board?
Thanks,
Hi Paul,
There is another issue specific to the Nucleo F411RE here:
We think this will help you. If not, please create a new GitHub issue as that will get you a response from the ST team.
Ralph, Team Mbed
posted by Ralph Fulchiero 05 Feb 2019
