7 years, 2 months ago.
What's wrong with my code? Only works with an extra printf in main().
So I'm a bit of a noob when it comes to C/C++ to go easy on me. However, I've been playing around with some of the examples and am trying to get the following simple NTP example working. I'm using mbed-cli 1.8.3 with a nucleo_f767zi. I'm using the USER_BUTTON on the board to toggle an LED via InterruptIn and also to set a flag that should request and print out the current time.
However, it only works if I add some dummy printf to the main while loop outside of the flag test. What is going on?
#include "stats_report.h"
#include "ntp-client/NTPClient.h"
DigitalOut led1(LED1);
InterruptIn btn(USER_BUTTON);
Serial usb(USBTX, USBRX);
EthernetInterface eth;
int flag = 0;
void buttonIsr() {
    flag = 1;
    led1 = !led1;
// main() runs in its own thread in the OS
    eth.connect();
    usb.printf("ip address = %s\n\r", eth.get_ip_address());
    btn.rise(&buttonIsr);
    NTPClient ntp(&eth);
    time_t timestamp = ntp.get_timestamp();
    usb.printf("Current time is %s\n\r", ctime(&timestamp));
    while (1) {
        if (flag == 1) {
            usb.printf("button pushed\n\r");
            while(timestamp < 0) {
                wait(1);
            flag = 0;
Hello, Shareef
Since the compiler does not know anything about interrupts and the interrupt service routine isn't called directly at any point in your code, it concludes that it's a good candidate for code optimization/reduction. You can prevent such optimization by declaring the flag variable as volatile.
volatile int flag = 0;
It will mean for the compiler that such variable can change its value any time during the program execution and it won't optimize the related code.
NOTE: When you tried to print the flag variable in the main function the compiler was prevented to optimize the flag related code as well that's why it worked as expected.
