7 years, 1 month ago.
How to slove the "error: Unknown error (-4001)"
I use the application “mbed-os-filesystem” and nucleo.when i download into my board.The led is on and off and the error occurs.I don't know how to solve it .Can you help me?Thanks.
What application? Could you provide a link?
Try with the official example. https://github.com/ARMmbed/mbed-os-example-filesystem
That is :https://os.mbed.com/users/pokrovsci/code/mbed-os-example-filesystem/ And i changed the type of blockdevice to SPIFblockdevice.my spif flash is w25x and i config the pin .but the error is still .I don't know how to do.
posted by 24 Jan 2019- include "mbed.h"
- include "SPIFBlockDevice.h"
Create flash device on SPI bus with PTE5 as chip select SPIFBlockDevice spif(PTE2, PTE4, PTE1, PTE5); /*SPIFBlockDevice spif( MBED_CONF_SPIF_DRIVER_SPI_MOSI, MBED_CONF_SPIF_DRIVER_SPI_MISO, MBED_CONF_SPIF_DRIVER_SPI_CLK, MBED_CONF_SPIF_DRIVER_SPI_CS);*/ SPIFBlockDevice spif(D11, D12, D13, D10); int freq = 40000000; SPIFBlockDevice spif(PA_7, PA_6, PA_5,PB_6,freq); int main() { printf("spif test\n");
- ifdef MBED_MAJOR_VERSION printf("Mbed OS version %d.%d.%d\n\n", MBED_MAJOR_VERSION, MBED_MINOR_VERSION, MBED_PATCH_VERSION);
- endif Initialize the SPI flash device and print the memory layout int err = spif.init(); printf("%s\n", (err ? "Fail :(" : "OK")); if (err) { error("error: %s (%d)\n", strerror(-err), err); } printf("spif size: %llu\n", spif.size()); printf("spif read size: %llu\n", spif.get_read_size()); printf("spif program size: %llu\n", spif.get_program_size()); printf("spif erase size: %llu\n", spif.get_erase_size());
Write "Hello World!" to the first block char *buffer = (char*)malloc(spif.get_erase_size()); sprintf(buffer, "Hello World!\n"); spif.erase(0, spif.get_erase_size()); spif.program(buffer, 0, spif.get_erase_size());
Read back what was stored spif.read(buffer, 0, spif.get_erase_size()); printf("%s", buffer);
Deinitialize the device
spif.deinit();
That is the application.The os is 5.11.2 and spiffilesystem.The Flash Memory is W25xx.
The other error is :
++ MbedOS Error Info ++
Error Status: 0x80FF0100 Code: 256 Module: 255
Error Message: Fatal Run-time error
Error Value: 0x0
Current Thread: main Id: 0x200023B8 Entry: 0x800A539 StackSize: 0x1000 StackMem: 0x200013B8 SP: 0x20002338
For more info, visit: https://armmbed.github.io/mbedos-error/?error=0x80FF0100
MbedOS Error Info
error: Unknown error (-4002)
HMMMM I'm trapped...
I believe you should configure your pins for initializing the Block Device API overriding the mbed_app.json with something similar to
"target_overrides": {
"NUCLEO-L476RG": {
"target.features_add": ["STORAGE"],
"target.components_add": ["SPIF"],
"spif-driver.SPI_MOSI": "PTE2",
"spif-driver.SPI_MISO": "PTE4",
"spif-driver.SPI_CLK": "PTE1",
"spif-driver.SPI_CS": "PTE5"
The initialize de BlockDevice with
