7 years, 2 months ago.
Using onboard mini USB to send/receive data on MAX32630FTHR
I would like to use the mini USB on the MAX32630FTHR board to transmit and receive data from a PC. So far, I have been able to use serial communication only through the DAPLINK. I am working on designing a wearable sensor system which will synchronize data to the PC when it is charging. At this time, I am trying to avoid using the BLE. Is there a way to use the mini USB as a serial port as well as charging port for this board?
