7 years, 2 months ago.
UDP socket (sending buffer)
UDP socket:
Trying to send 16Kb in one go, does not seems to work. Here my command:
int ret = td_sock.sendto(td_addr, buff2, 16384); :-> this does not work!
Sending 1024 bytes in one go, works fine . Here my command: int ret =td_sock.sendto(td_addr, buff2, 1024); :> this works fine
Anyone an suggestion how to let function the 16Kbyte command? I need to send the data in one 16Kb block for application timing reasons.
Wbr,
Jos
